Basic Current Question
Ryankevin1201
Joined Sep 1, 2020
Hello, if I hook a circuit board up to a power supply, do you set a specific current level?
Or does the board just draw what current it needs? Could you accidentally send too much current to a circuit card?
I want to power a circuit card and it’s 5V supply, but do you usually set the current on a lab power supply or how does that work?
thank you in advance!
kevin
35,299
What is a CCA?
I am going to assume that you are using a lab bench power supply that allows you to set the voltage and current limits.
Make an estimate of the maximum current your load will require.
Set the PSU current limit to 20-50% above the maximum current.
For example, if the max load current is 100mA, set the limit to 150mA.
Ryankevin1201
Joined Sep 1, 2020
What is a CCA?
Set the PSU current limit to 20-50% about the maximum current.
Ok - circuit card assembly
