Basic 12V DC PSU resistance & current distribution Question
jc29
Joined Aug 23, 2014
Hey guys,
Been getting into home automation as of late, but am weak on the electronics side, hoping for a bit of direction to build my foundation.
I have a basic question regarding supply multiple DC devices from a single DC power supply.
Scenario is:
INPUT:
12V 5A DC power supply DC plugs
OUTPUT:
2x 12V 1.8A DC 2wire fans
1x 12V 1A water pump
If I only have 1 of the 3 equipment running, then does the water pump only take the 1A it needs. I figure with the other fans seen as an open circuit would then mean the 3.6A would also flow into the water pump by KCL.
So correct me if im wrong, I'd need to setup a set of parallel resistors for the case when the switches are open.
If that makes sense?
BobTPH
Joined Jun 5, 2013
11,660
When you have two lamps plugged into an AC outlet, and one of them burns put, does the other ine double in brightness? If you can confidently answer that, you should be able to answer your question.
Bob
35,201
A 12V car battery can crank out 200A.
One light bulb takes 1A, another takes 4A. The radio draws 2A. Yet they are all connected in parallel to the same 12V source without burning out.
BobTPH
Joined Jun 5, 2013
11,660
I’ve always wondered, if a powwr supply worked the way a lot of beginners think it does, i. e. put out the same current independent of the load, where do they think that current goes when no load is connected!
Bob
jc29
Joined Aug 23, 2014
Thanks guys appreciate the answers, the analogies really helped.
Just had a bit of doubt there, revised KCL and bit more reading into power supply operation and got it, always learning.
Cheers!
