Not sure circuit is relevant to question but....
Designed for about 3.4 Mhz
Inductors (t50-2) and the capacitors are 150pf in parallel with trimmer caps (china)
the problem now is that it peaks at this frequency but it also peaks at about 11Mhz
10Vpp in then a peak at about 3.4Mhz but with amplitude of 1vpp
10Vpp but the peak at 11Mhz almost 9v
Please what can TS do? what is he missing??? Need to solve this badly
Thank you
This is my 2nd attempt. 1st attempt, I used 4.3uH inductors with appropriate caps but same problem
Thank you
