while making a Balun (input single Ended / output Differential); should the center tapped be AC grounded or DC grounded? I searched for different post but there only ground is discussed not mentioned about its type.
Hi CrutschowDepends upon what load you are driving with the balun.
Does it have any DC voltage?
You can do that if you need a DC bias.What if i use the center tapped terminal to provide the Bias?
Depends upon the frequency and the power level.how can we estimate the size of balun before matching (eg. let design freq is 40G)?
