Back emf at ac relays
mrtrusted
Joined Feb 18, 2020
9
I have designed a circuit is about digital outs. I controll a relay with a logic(12vdc) and then the relay's normally open contact triggers 2nd relay. 2nd relay is triggered with ac signal(220vac). If i triggered 1st relay speedly,i think 2nd relay generates back emf. Because it causes to reset the logic. I have tried varystor between normally open contact and notr. But it doesnt effect. It still resets.
How can i suppress ac back emf in the relay?
mrtrusted
Joined Feb 18, 2020
9
Hi mr.
I attached my design. In design, NO_2 contact goes to other relay's coil. I tied up 220vac to COM_2 and also connect varystor between this NO_2 and notr. Still it gives back emf.
KeithWalker
Joined Jul 10, 2017
3,628
Hi mr.
There are lots of things that could cause this problem. The most likely is that the input to the switching circuit is picking up electrical noise radiated by the AC relay when it is activated.
How far apart are the two relays? what kind of wire/cable do you have connecting the contacts of the 12V relay to the coil of the 220V relay? Is the supply driving the 12V circuit connected to earth ground? What is connected to the input of the 12V relay switching circuit? How far from the circuit is it? what kind of wire/cable are you using to connect it to the input?
All of these things will have an effect on how immune to noise your circuit is.
Regards
Keith
mrtrusted
Joined Feb 18, 2020
9
Yes, i mean ac coil. There is not rc snubber in the circuit. Where do i add rc snubber to?
There is a 0.75mm2 30cm wire between 12v relay and 220v relay. I usually use it.
There is not earth ground in the logic part. There are just dc+ and dc- .
I controll the 12v relay switching with sn74hc595n ic shift register. It controll the RELAY_2 part in the sketch. It controll also other 7 relays. I think it is affected from back emf.
vu2nan
Joined Sep 11, 2014
357
A surge suppressor would need to be connected across the AC coil. A 220 Ω 1W resistor in series with a 0.5 μF 350 V ~ metallised polypropylene capacitor would suffice. The MOV across the driving relay contact would not be required.
Regards,
Nandu.
Marley
Joined Apr 4, 2016
519
The AC relay coil can be suppressed with a snubber network - a resistor and capacitor in series.
A better way is to use a Varistor. Something like this2213616-40.jpg. They have a resistance that is high until a certain voltage is reached, then the resistance drops. They are "bidirectional" so they work with AC. They are normally specified with a voltage rating that will depend on your application.
Remember that with a AC supply, the peak voltage is √2 (1.414) times the RMS voltage so the varistor must be able to tolerate the peak voltage without going into the low resistance region.
mrtrusted
Joined Feb 18, 2020
9
I am using MOV-S07K275E2 varistor. But it cant prevent the back emf. Can the error be because of other things?
I will try a rc snubber 220Ω 1w resistor and 0.5 μF 350 V capacitor.
KeithWalker
Joined Jul 10, 2017
3,628
What is controlling the shift register? It would be much easier to solve the problem if we could see the whole picture.
cmartinez
Joined Jan 17, 2007
8,897
What's worked for me in the past better than an RC snubber, is a TVS diode. Since you're working with 220VAC at the coil, peak voltage is squrt(2)*220 = 311 Volts, more or less. So a bidirectional 342V TVS such as this one ought to do the job.
mrtrusted
Joined Feb 18, 2020
9
I have added to Ac coil 220Ω 1w resistor and 0.5 μF 350 V capacitor. But now there is always voltage on the coil. I measured it 40-80 vac when i didnt trigger the relay.
Microcontroller(pic24f) is controlling the shift register. Microcontroller runs normally. It is not affected.
Will i add the tvs diode between ac coils?
ericgibbs
Joined Jan 29, 2010
21,654
hi,
Is the R and C snubber across the actual coil of the AC relay.??
If yes, is the DC relay not energised when you measure the 30-80Vac across the AC relay coil.??
It suggests you have a wiring problem.
When posting a diagram its a good idea to include on the drawing the the Common Gnd reference line.
E
eetech00
Joined Jun 8, 2013
4,753
hi
I don’t know what your planning to do with this board...but hopefully you’ve taken safety requirements into consideration for the 220 VAC circuit components and traces on the PCB.
Otherwise, I would move the DC relay off the board..
just a suggestion...
eT
mrtrusted
Joined Feb 18, 2020
9
I just quickly drew necessary part for you. I cant send all design.
Is the R and C snubber across the actual coil of the AC relay.?? ( Yes )
If yes, is the DC relay not energised when you measure the 30-80Vac across the AC relay coil.?? ( No, it is ac relays coil)
ericgibbs
Joined Jan 29, 2010
21,654
Hi mr,
This line of text is contradictory .??
I asked:
You replied:
Please post a sketch showing which AC has the 30-80Vac across its coil.
E
mrtrusted
Joined Feb 18, 2020
9
Sorry, i misunderstood. Althougt i didnt energize the dc coil, there was 30-80Vac across ac coil.(If I add rc 220Ω 1w resistor and 0.5 μF 350 V capacitor across ac coil)
mrtrusted
Joined Feb 18, 2020
9
I have tried your suggestions. But they didnt effect. I have added the MOV between dc relays normally open contact and ground. The back emf(error) is gone when only i did that. I have tested a while. There isnt any problem. Can it be use like that? if i use, Can it cause a problem?
E General Electronics Chat 22
