Axial flux motor with single coil
jorge.braque
Joined Mar 31, 2017
Disclaimer: I am not an expert, only enthusiast.
Hi, i want to experiment with a small scale axial flux motor and a single coil.
The first question is what should be the polarity of the magnets? Same or alternating?
The second question is what should be the shape of the coil. Is a core needed?
The output should be about 5 Volts.
Alec_t
Joined Sep 17, 2013
15,167
Since we don't know your aims and you state that you want to experiment, you would be better placed than this forum to answer all the questions you are asking. A bit of Googling should find you lots of references to axial flux motors/generators.
Your thread title refers to a motor, but you mention an output of ~5V. Is your 'motor' in fact to be used as a generator?
Danko
Joined Nov 22, 2017
2,256
jorge.braque
Joined Mar 31, 2017
I was thinking blowing up the Pentagone.
I did some research but all the references were at large scale and were using multiple coils generating multiphase current. So i couldn't get all the answers.
Yes, actually i want to use it as a generator.
