AVR tiny 416 SPI SSD not working
Daniel Morley Jack
Joined Dec 5, 2019
I am trying to use SPI to talk to a 25R3911b to get it to read a register with a SPI right command 0x42. To read the register at 02 address. The function gives the right address on the MOSI line but the chip select goes high and I cannot figure out why.
void Comand25r3911b (uint8_t commandaddress, uint8_t data )
uint8_t TEMP;
TEMP=commandaddress;
SPI_0_write_block(&TEMP,1);
TEMP=data;
Daniel Morley Jack
Joined Dec 5, 2019
Ignore previous code
void Read25r3911b (uint8_t commandaddress)
{ uint8_t data;
uint8_t TEMP;
PORTC_set_pin_level(3,low);
PORTC_set_pin_level(3,high);
// SPI_0_read_block(&TEMP,1);
Daniel Morley Jack
Joined Dec 5, 2019
{ uint8_t data;
uint8_t TEMP;
while (SPI_0_status_busy()); //1
//PORTC_set_pin_level(3,high);
This version of the code never gets out of comment 1
