Hello Everyone!
I was trying to receive characters from the PC through serial programming USB with FT232RL and atmega644P and trying to display it on LCD. I have been using PORTB as data port of LCD, PORT D for control pins of LCD.
Below is the code i have been trying to get the output from. I am getting wrong characters displayed on LCD. Also, the characters remains the same even though i am trying to send different ones. I am not able to figure out where i have been going wrong. It would be really great if any of you can help me figure it out. Thank you.
Code:
#include <avr/io.h>
#include <util/delay.h>
#include <stdlib.h>
#include "lcd.h" // include LCD library
#ifndef F_CPU
#define F_CPU 1000000UL // set the CPU clock
#endif
#define BAUD 4800 // define baud
#define BAUDRATE ((F_CPU)/(BAUD*16UL)-1) // set baudrate value for UBRR
// function to initialize UART
void uart_init (void)
UBRR0H=(BAUDRATE>>8);
UBRR0L=BAUDRATE; //set baud rate
UCSR0B|=(1<<TXEN0)|(1<<RXEN0); //enable receiver and transmitter
UCSR0C|=(0<<UMSEL00)|(3<<UCSZ00);// 8bit data format
// function to send data - NOT REQUIRED FOR THIS PROGRAM IMPLEMENTATION
void uart_transmit (unsigned char data)
while (!( UCSR0A & (1<<UDRE0))); // wait while register is free
UDR0 = data; // load data in the register
// function to receive data
unsigned char uart_recieve (void)
while(!(UCSR0A & (1<<RXC0))); // wait while data is being received
return UDR0; // return 8-bit data
// main function: entry point of program
int main (void)
DDRB=0XFF;
DDRD=0XFF;
Lcd8_Init(); // initialize LCD
unsigned char a;
char buffer[10];
uart_init(); // initialize UART
while(1)
a=uart_recieve(); // save the received data in a variable
itoa(a,buffer,10); // convert numerals into string
Lcd8_Clear(); // LCD clear screen
Lcd8_Cmd(0x80);
Lcd8_Write_Char(buffer); // display the received value on LCD
_delay_ms(100); // wait before next attempt
return 0;
