average current mode control of switching power supplies
anhnha
Joined Apr 19, 2012
904
Hi MrAl,
My chrome and downloaded text file show exactly the same. :)
For the code, I see it is very similar to C programming but there are some strange commands to me such as EuphoriaStart, atom type.
However, it is simply enough so I can create my own version using C programming.
So what should we do next? Calculate vC and iL for a pulse trains and change step size h also to see how it affect?
MrAl
Joined Jun 17, 2014
13,793
Hi MrAl,
Hello again,
Yes calculating vC and iL is really the whole goal for this try.
You can vary h too in order to see the effect it has on the outcome.
"EuphoriaStart()" is just a command to tell the interpreter that there is program code to follow, so handle that as a program rather than just text. That way i can mix program code with plain text without using rem's and such, and create a document that looks like a document rather than one big program :)
This method of analysis is very handy. The next step would be to see if you can add stuff to teh circuit and get the results from that. I guess you realize you have to change the code to make E1 equal to 1 sometimes and E1 equal to 0 other times, and if you want 12v input then make E1 12 sometimes and E1 zero when the pulse is off, through program code such as if/then/else statements.
So your goal would be twofold then:
1. Write new derivatives and solution sets.
2. Run the program and see how well it works.
I should mention that the derivatives and solution sets should be written in a more clear form. I usually use functions but even plain code will do it.
So for a derivative such as (fictitious here):
dv/dt=E/RC-v/RC
di/dt=i-v/R
and solution:
v=v+h*dv/dt
i=i+h*di/dt
we would instead just do:
DV=E/RC-v/RC
DI=i-v/R
and then we can do:
v=v+h*DV
i=i+h*DI
with the exception that we have to keep calculating DV and DI over and over again, which means a function could be used instead.
The organization of the program seems neater that way but it's up to you.
Yes the language used is just like a subset version of C so it is easy to follow.
A console app does the trick too, unless you want to get fancy and add a nice window and maybe even a graph.
If you get ambitious you can try to develop a second order method. We are using a first order method for now, but a second order method is more accurate. It does complicate the code though.
