Automatic water filler circuit with touchless water level detection.(initial question "Inverting sensor output voltage")
Status
Not open for further replies.
sghioto
Joined Dec 31, 2017
8,665
Have you tried cleaning the bottom of the boards? Looks like some flux or small solder particles everywhere.
I see one issue the relay contacts are only rated at 3 amps.
Lifeisfun
Joined Feb 17, 2023
102
You are right, that's why I had to put the red jumper there, little arcing in progress killed that trace.
Lifeisfun
Joined Feb 17, 2023
102
Yes, that's the one that does it, I even swapped the power supply using the other one, looked way safer to me
The relay 3A rating @120V should be plenty right?
Board 2
cleaned, blob removed, 100nF cap from pin5 to negative added, no change.
sghioto
Joined Dec 31, 2017
8,665
I can't bring up the specs on the 110vac solenoid you posted but 5.5 amps seems like a lot, that's 605 watts where the 12 volt version only uses 6 watts.
Post a photo of the actual valve so I can read the numbers please.
Lifeisfun
Joined Feb 17, 2023
102
Yes, I find the markings strange, I thought 5.5VA was 5 watts so about 50mA @ 120V :)
Diode replaced, no change
Resistors measured, both good
sghioto
Joined Dec 31, 2017
8,665
That's correct 5.5VA is around 5 watts or 50ma so the contacts should be fine.
I don't know if you answered the question if board #1 (which is the one with the PS removed and works when holding the wires) works OK if the solenoid and 110vac are not connected.
Lifeisfun
Joined Feb 17, 2023
102
No, didn't even connect the solenoid to that board yet, only listening to the relay and having tester attached to the relay contacts to verify closed/opened.
When connected it will switch on
I can just touch the upper sensor and it will turn off (shouldn't) touching lower does nothing.
If I hold the upper or lower output wire in my finger tips I can control the sensors and it work like it should.
Lifeisfun
Joined Feb 17, 2023
102
Just touching the pads with my fingers ( they are in little plastic bags so no contact)
Also measured the sensor output and they still activate correctly just the relay does nothing.
Swapped sensors as well, no difference
Status
