Automatic water filler circuit with touchless water level detection.(initial question "Inverting sensor output voltage")
Status
Not open for further replies.
sghioto
Joined Dec 31, 2017
8,745
Can you post a HD photo of the bottom side of that relay module?
If you're up to the task can you assemble the circuit I posted on a perf board and integrate into the relay module?
Lifeisfun
Joined Feb 17, 2023
102
View attachment 287773Try this arrangement.
When the tank is full both sensor outputs are low and so is the output from the 555. When the water level drops below the bottom sensor both sensor outputs will be high triggering the 555 output high.
D1 and R1 form a latch function to keep the output on the 555 high as the water level rises and the bottom sensor goes low again.
When the water level rises to the top sensor the low output will reset the 555.
Will try that, thank you.
In this case it will be probably easier to get the IC and build it from scratch then rework the old controller.
In this configuration it should work with my sensors direct?
Lifeisfun
Joined Feb 17, 2023
102
The sensors must have internal pullup resistors, but the relay should have activated with out the sensors connected. Are you sure the 555 is good?
Don't know if it's good or not, will order couple new.
Postec pic of my nasty wiring above :)
only positive voltage is 3.5V on pin5 and power on 8
0V on the relay
LesJones
Joined Jan 8, 2017
4,533
Re post #38. It should work just as well with a 10K pull up resistor. Did you measure how low the output of the sensor went ?
The sensor may have an internal pull up resistor that did not allow it's output to go low enough to turn off the added transistor.
Les.
sghioto
Joined Dec 31, 2017
8,745
Updated schematic if sensor has pullup resistor.
Without pullup resistors. Looking at the image in post #2, don't see a pullup resistor.
Status
