You are right, that's why I had to put the red jumper there, little arcing in progress killed that trace.Have you tried cleaning the bottom of the boards? Looks like some flux or small solder particles everywhere.
I see one issue the relay contacts are only rated at 3 amps.
No because you say the solenoid valve requires 5.5 amps.The relay 3A rating @120V should be plenty right?
Will do, it's rated AC120V/5.5VA on the coilNo because you say the solenoid valve requires 5.5 amps.
Post a link to the valve.
Yes, that's where I sucked away the blob, I can try to replace it, got buch of them.This D1 is the one I was speaking of.
Yes, I find the markings strange, I thought 5.5VA was 5 watts so about 50mA @ 120VI can't bring up the specs on the 110vac solenoid you posted but 5.5 amps seems like a lot, that's 605 watts where the 12 volt version only uses 6 watts.
Post a photo of the actual valve so I can read the numbers please.
Yes, you are right!OK then touching the LOW sensor should not shut off the relay but touching the HIGH sensor should
