Automatic Voltage Regulator
Dumken
Joined Oct 7, 2014
31
Good day everyone. Pls can someone help me with a material or textbook that will give a detailed explanation of AC automatic voltage regulator design. Thanks.
30,660
I have built a simple one using a LM311.
Or do you need to duplicate the current types, the one above was similar to the first electronic types that replaced the electromagnetic ones in automobiles.
Dumken, you need to describe more about your application. Give us specifics. Your words so far are too general. If you don't have any specifics, you need to get them or you can't design something like this. Here are some questions for you to get specifics:
How do you intend to use this? What is the input and the output, AC/DC, voltage, frequency? What supplies the input, battery or mains or what? What does the output connect to?
If you're talking about going from a low-voltage DC input (like a car battery 12V) to mains-type AC voltage (220V 50Hz or 110V 60Hz) it's called a power inverter or just "inverter". Google "inverter design" and you'll find a lot of stuff.
30,660
Wat i need is the electronic type. Thanks
The LM311 electronic version is a simple circuit, the reason that it was replaced in automobiles is due to the the radio interference caused and inline suppressors were needed for the radio.
I have also used it to control the field for 240vdc generators also.
tcmtech
Joined Nov 4, 2013
2,867
My guess is he needs a line voltage stabilizer like a constant voltage transformer.
Otherwise I associate the term automatic voltage regulator with generators.
alfacliff
Joined Dec 13, 2013
2,458
the switch elements are make before break, usually submerged in oil. usually seen in a group of three that look like transformers on a pole.
