automatic tinting lcd sunvisor
helpmemaster
Joined Apr 14, 2015
2
I want to make an LCD a sun visor (3 ft wide) placed in a windshield that automatically tints in broad daylight. Is it possible if I use the same materials used in a 3D shutter glass? If possible, where can I get a transparent LCD material that big? I tried disassembling the lcd on my broken laptop to see what kind of lcd it has but the lcd was not clear like a glass.
http://hackaweek.com/hacks/?p=978
any help would be great.. thank you!!
Externet
Joined Nov 29, 2005
2,635
LCD screens as in televisions, laptops, monitors have a thin layer of polarizing film on top. That is what makes them not fully transparent.
I once removed that self adhesive polarizing layer out of a television LCD very carefully and ended with a clear glass screen. I still have it somewhere in the attic. I believe that is the principle used in some transmissive overhead LCD projection, and some people have done the modification for such application. Will see if I find a link :
----> http://displayblocks.org/fundamenta...-lcd-out-of-your-monitor-without-breaking-it/
You will still need to drive all the screen pixels with some signal to vary the amount of transparency/color. The white backing also has to be removed, leaving a fully transparent glass screen until driven with pixel activation.
Found it ! ----> http://chrismeyer.org/projects/lcd-overhead/
helpmemaster
Joined Apr 14, 2015
2
Can I see a picture of the LCD you got from your tv? Is it clear? The LCD I got from the laptop was transparent but its texture is similar to a jalousie window.
Externet
Joined Nov 29, 2005
2,635
Just checked the attic. The monitor is still there, reassembled, put back together. There have to be pictures hung on the net.
Sorry, I do not use Google ----> https://duckduckgo.com/?q=see+trough+display&images=&iax=1&ia=images
Re-thinking, seems you still need the polarizer, but a clear one.
Some LCD have an antireflective film layer built-on the polarizer or separate. That would have to be peeled off.
Unsure if this uses polarizer, believe yes, but a clear non-hazy one, and no diffuser nor backlight.----> http://www.geekalerts.com/u/flagstone-clock.jpg
And on the market : ----> http://crystal-display.com/components/displays/transparent-displays/
----> http://phys.org/news/2012-01-samsung-transparent-inch-lcd-panel.html
----> http://lcdtransparent.com/
