Hello from a newbie, both to the forum and (relatively) to electronics.
I'm trying to find a method of replacing a mechanical on-off switch with an electronic version. A much simplified version of my circuit is:
A connects to B via PL1/J1 and passes low frequency (possibly down to 0.01Hz) signals by taking B's input low via the diode.
My aim is to replace S1 with an electronic equivalent that switches on when PL1 is plugged into J1 and off when the plug is removed. Mechanical switches in the plug/socket are not acceptable!
The only requirements are that in the off state virtually no current should be drawn from the battery and in the on state, since A itself only draws about 6-7ma, any additional load required by the extra circuitry should ideally be 1ma or less. Obviously this is to conserve battery life.
Am I seeking the impossible?
Regards
richard.
Regards
richard.
