Automatic gain control (AGC)
omar675
Joined Apr 5, 2018
5
Hello everyone
I have a project for my electronics course where iam supposed to build a speech amplifying circuit that has a constant output no matter how loud or low the input is (if i speak loud the circuit is supposed to lower the gain and if i speak with a low tone the circuit is supposed to increase the gain with both outputs being the same)
Now we have a circuit and we tried to simulate it using orcad we used different input voltages and we are supposed to get the same gain for all but we kept getting the wanted result for the upper not the lower part
AlbertHall
Joined Jun 4, 2014
12,663
That circuit won't keep the output at the same level though it will reduce the range of variation - it will compress the compress the audio range.
You might try a non-inverting integrator with gain between C1 and R5. You will have to play with the gain and integrator time constant to get suitable performance and stability.
38,946
The problem with that circuit is that the gate-source voltage is modulated by the signal, causing a variation in FET on-resistance between the positive and negative peaks of the signal, generating the observed asymmetry.
Here's a circuit that connects the FET to shunt the signal to ground so that can't happen.
It uses a P-FET instead of an N-FET.
What's the desired dynamic range of the AGC, i.e. the softest to the loudest signal.
omar675
Joined Apr 5, 2018
5
Hello again
First, thank you all for the help
We got the circuit, modified it, and we tested it and got it working, as shown in the pictures i uploaded.
However, the speaker that is required to use is 8 ohms and since it will be connected parallel to the 10k resistor, it reduced the 10k value too much which caused the circuit to not function the way the way that we needed, I was adviced to use an amplifier, but i really didn't know how to use....
Sorry but some help would be really appreciated again :)
