Auto Battery Polarity
Don P
Joined Sep 17, 2014
7
I am trying design an auto polarity for a 9V battery. This allows the user to insert the battery either direction and the circuit will compensate and switch the polarity. I found this H-Bridge design that works some of the times. However, every now and then, the mosfet will smoke and I am not sure if it is caused by a race condition in switching the mosfets.
Does anyone have any idea of a better design or a modification to this design to stop the mosfet from smoking. :). Attached is the schematic.
Don P
Joined Sep 17, 2014
7
Just build a full wave bridge out of Schottky diodes.
I looked at this design and it is simple and sweet. I was worried about the voltage drop using the diodes. I am hoping for every last bit of juice from the battery and went with the MOSFET. As for the mosfet, I think I might of stumbled onto something. I don't have any inline resistor to the gates and on another forum they mention that the mosfet gates are extremely sensitive and any transient spike will fry the mosfet gate to close position causing that will result in a short. I am going to try the above circuit with inline resistor and will report back.
BR-549
Joined Sep 22, 2013
4,928
Is this a 9 VDC transistor battery? The little rectangular unit with polarized connectors? This is new. Have you ever connected a 9 volt battery backwards? Did it do any damage? A most curious situation. Is the power receptacle plug out of view? Is the battery difficult to retrieve and flip? Of course #12 has the proper solution. But with a polarized plug and a protection diode....what is the need?
Don P
Joined Sep 17, 2014
7
Yes, it is a standard transistor battery. We are not using standard 9v battery clips (with different sizes for +/-), but springs in handle that the battery drops in. Even though we have a label for polarity and a diode for protection, the customer is wanting to put the battery in either way and have it work. That is the need, to meet the customer wishes.
38,806
You can use a 10k ohm resistor or larger in series with each pair of gate connections, since the switching speed of the bridge is of no consequence.
#12
Isn't that per diode?
Yep. You caught me in a mistake. I assumed the curve was for the device they are selling, not each part inside the device. :(
At 20 ma, it's about .175V per diode...0.35 volts per bridge.
Definitely something you can beat with mosfets.
alfacliff
Joined Dec 13, 2013
2,458
a possible reason your mosfets smoke is that the source to gate juction has a large amount of capacitance, you must discharge it when the thing is off, otherwise the mosfet s still turned on till it discharges.
Don P
Joined Sep 17, 2014
7
This makes a lot of sense. See the proposed schematic. Is this the concept? I am concern about leakage with the resistance. Would should the Rgs be for 9V battery? I seen some comments recommending 47K, but with 4 gates, this is serious leakage and will drain the battery quickly.
38,806
Edit:
A possible source of failure is high shoot-through current as the bridge is turning on. My simulations showed a very high current when the bridge initially had power applied to it due to two MOSFETs in series being momentarily on. A small resistor (1 ohm) in series with the battery will minimize this surge. Also reduce the value of the resistors in series with the gate to perhaps 100 ohms or so to reduce the duration of the shoot-through.
38,806
I found this H-Bridge design that works some of the times. However, every now and then, the mosfet will smoke and I am not sure if it is caused by a race condition in switching the marmosets.
I don't see "this H-Bridge design".
Marmosets are small new world monkeys. :confused:
Don P
Joined Sep 17, 2014
7
All,
Thanks for the help. I have built up a few different designs and the attached is what I am going to go with. One think that slip through the crack was the on the FDC6305 / FDC6312 MOSFET, the Vgs is max at 8V. I was driving this with 9+ which exceed the mgf limits.
I selected a higher power MOSFET, might be an over kill, but, seems to work. I am using a Complementary MOSFET with N & P channel sharing a common drain (AON3613). This MOSFET has max Vgs of +/- 20V. I added the 1 ohm resistor in series with the battery and added zener diodes (15v) BZV55C15 to protect the Vgs to not exceed it maximum.
I have pounded this circuit with variety of voltage and spiked the voltage and it seems to hold up. I have yet to smoke the mosfet.
Thoughts?
