audio driving an LED circuit
BobbyTheD
Joined Mar 10, 2016
37
Hi there -
I've been looking through the forum back catalog and the many, many websites out there...but I haven't figured out what the issue is yet.
I'm using a simple LED NPN transistor driver - this circuit, identically: http://www.learningaboutelectronics.com/images/LED-driver-circuit.png
But the audio signal is "line level", around 1v, and the LED is connect to +5v and ground. The LED stays illuminated at all times.
My goal is to use an audio signal, with as little circuitry as possible, to fully drive an LED. Is there a solution?
#12
Audio frequencies turn the LED on and off so fast you can't see it go off. You need to change the parameter of the audio signal to get a useful response. This is usually done with a rectifier, a capacitor, and a resistor to form a time constant slow enough for you to see the amplitude change.
BobbyTheD
Joined Mar 10, 2016
37
The audio, in this particular case, is spoken English. I was thinking an envelope follower wouldn't be necessary, since there are plenty of silences... Is that not the case?
12,143
It depends on all of the stuff not in that schematic, the audio source, any coupling capacitors, any DC boas, etc. For example, if the audio is riding on 1 V DC, then the LED always is on. If the quiet passages aren't so quiet, then the LED always is on. If if if
Separate from that, your circuit almost certainly will not differentiate between syllables.
BobbyTheD
Joined Mar 10, 2016
37
Ah, well, that does help. I put a cap prior to the transistor and it seems to be a lot closer to working now. There must've been some serious DC coming in. However, the light doesn't get very bright with the audio signal now. Is this a common issue? I would've thought this is a problem that's been solved many times over, by now..
