audio amplifier
Audioguru
Joined Dec 20, 2007
11,248
I modified a simple amplifier so its output power is as high as possible for a 9V supply and it has some gain. It is simple so it has about 2% to 5% distortion. Its distortion is less when it has more negative feedback but then its gain is low.
salmanshaheen_88
Joined Mar 5, 2009
88
well in practical I guess there must be some noise as well so how I will remove that and I have no idea which mic and speaker to use so.................
Audioguru
Joined Dec 20, 2007
11,248
You have a darlington transistor that is biased "do not ever bias a transistor like that" as we were told in university because the hFE of every transistor is different. It also has DC current in the 10 ohm speaker which is bad. Its voltage gain is only about 10 but for a mic as the input it must have a voltage gain of 100 to 200.
