Audio Amplifier Improvements
abdullahab4
Joined Jan 24, 2018
6
Hello Guys, I am creating a class D audio amplifier using 2 outputs from a 3 phase bridge. The 2 PWM outputs (R and Y) are at opposite polarity to provide a differential voltage at the output.
My switching frequency is 10KHz and the output frequency response showed a cutoff frequency of 400Hz. What does this indicate?
Also, how can i improve the performance of the audio amplfiier? Is it by increasing switching frequency? Reducing deadband time? or anything else?
38,805
The switching frequency should be a least 10 times the highest audio signal frequency of interest.
Since you didn't post your complete circuit I can't tell why your frequency response is 400Hz.
