Audio amplifier - DC on output
AlbertHall
Joined Jun 4, 2014
12,652
C103 and C106 voltages?
What's the history? One day it was working then next day it had this fault?
Working correctly, then stored for a long while, then it has this fault?
Other?
Ylli
Joined Nov 13, 2015
1,092
Yes, I have power on pin 4.
U101 Pin 2 detects an excess offset. It has a negative threshold of -0.12 volts and a positive threshold of 0.54 volts. And there are dividers from each channel into that pin, so that -25 mV should not trigger a fault. What voltage do you measure directly on U101 pin 2?
Now pin 4.... What voltage do you measure at U101 pin 4? Pin 4 should be no less that +0.9 volts, and no more than +10 volts.
markk8
Joined Feb 3, 2021
7
I think problem is with different grounds from two symetric power supplies. I found that uPC is connected to Vcc, but ground from (V). So voltage on pin 2 is -45V.
Ylli
Joined Nov 13, 2015
1,092
The uPC should be connected to system ground. It is powered by it's own diode and filter cap from the power transformer secondary. How have you got the power supply configured? I wasn't able to find anything on this online other than the schematic you posted - are you working from any kind of instructions?
