Audioguru again
- Joined Oct 21, 2019
- 6,826
The RC parts at the output of the power amp ICs prevent oscillation at a high frequency. The ICs are different so the RC parts are also different.
The output capacitor value determines the low frequency cutoff frequency. The formula is C= 1 divided by (2 x pi x R x C).
Then 250uF into 8 ohms cuts 80Hz by -3dB and cuts lower frequencies at -6dB per octave. 470uF cuts 42.5Hz by -3dB etc.
