atx power supply earth issue maybe help
carpetride
Joined Sep 10, 2018
23
hi ive built a amplifier lm3886 and a separate power supply from a atx conputer,, jumped up the voltage with a stepup converter and a filter capacitor unit ,,,,, as per attachments it plays lovely using mp3 player or phone but cuts out if i plug in a pre amp also ive disconected the earth in the power supply for the same reason ime guessing it a ground /earth issue,,,, any ideas ??? thanks
28,224
I don't see anything that looks like an isolation transformer in the first picture, or in the others. So you may not have any, or adequate, isolation from the mains. Such isolation is not only important, it is VITAL. My guess is that connecting a preamplifier that is not isolated causes an overload and thus the shutdown. To verify that you can try running the preamplifier on a battery and see if the problem remains. OR, try it with the preamp connected but not powered (no power connection at all) . That is my best thought not having much information at all about your hookup.
MaxHeadRoom
Joined Jul 18, 2013
30,807
It sounded to me the OP used a PC ATX P.S. which is normally isolated SMPS and common is referenced to earth GND, of which the OP has disconnected, as far as I can tell.
Max.
carpetride
Joined Sep 10, 2018
23
Max.
sorry ime quite new to this ,, can explain you explan in laymans terms as ime not familiar with the termilogy thanks
KeithWalker
Joined Jul 10, 2017
3,617
KeithWalker
Joined Jul 10, 2017
3,617
thanks for your interest ! yes its fully converted ,10 ohm resister in place between red wire and ground
Do you have a schematic of the amplifier? On most circuits using the LM 3886, the positive and negative supplies are symmetrical about ground potential. The common or negative terminal of the +12V supply in the ATX is connected to ground. By connecting the amplifier ground to the ATX ground, you are shorting out the amplifier's negative supply which will cause the ATX supply to shut down.
carpetride
Joined Sep 10, 2018
23
hi just tested on the atx power supp negative
carpetride
Joined Sep 10, 2018
23
hi ive just replaced the atx power supply with another standard smps (not from a pc ) and i have no ground issues !!! all works fine !!!!!!! although i would realy like to use the atx power supply so any idea why the atx shorts the amp (does not short the atx power suppy ) when it is earthed ????????
ericgibbs
Joined Jan 29, 2010
21,567
hi carp,
Do you have a sketch of what's inside the Filter rectifier.?
E
EDIT:
Checking your photo images, it looks something like this.
ericgibbs
Joined Jan 29, 2010
21,567
hi agian,
If that is correct, at the ATX the -V and Gnd are already connected together, so when you ground the Rect you are grounding out the booster etc.
E
EDIT:
Power off and measure the resistance from Booster neg In to Booster neg Out, I suspect there is a direct path on these two points. ???
carpetride
Joined Sep 10, 2018
23
hi thanks for your input but the issue is the atx power supply ie amp does not like being eathed when using atx ps .......its fine using another smps
carpetride
Joined Sep 10, 2018
23
hi agian,
E
EDIT:
ile have to strip it ! i think your right , what wouldyou sugest to do
ericgibbs
Joined Jan 29, 2010
21,567
hi,
The problem is the Filter rectifier circuit [ that's why I chose on your other thread to use a full bridge on each winding, it gives you more flexibility on how you can use it.]
If you could find a Booster that is electrically insulated between the input and output terminals, that could be used to drive the Filter/Rect.
E
EDIT:
Re-looking over what you want to do
ie: get a dual Voltage 'higher' supply from single voltage source, which has its neg terminal grounded [ATX supply] is not feasible.
carpetride
Joined Sep 10, 2018
23
to round up ive disconected the earth from atx power supply (yes could be dangerous) but possible to encase whole power supply to isolate it !!!!!!!!! amplifier works with no issues apart from a bit of noise coming through the speakers at low volume ! i dont think you can get rid of dc emi ????amp sepatately earthed
