Attenuation of a signal using a hex inverter
Sakux
Joined Mar 1, 2021
25
I encounter this part of a circuit that made an attenuation of a signal coming from a crystal. If I measured this sinus signal I saw an attenuation in the different stages of the path. I really don´t know how it works, mostly for the part of the IC E. Here is what I can measure with the oscilloscope in each point:
Amplitude (V):
  • 3 ---- 5,81
  • 4 ---- 1,91
  • 11 ---- 2,85
  • 10 ---- 4,10​
Can anyone be to kind to explain that or give me a clue of what is happening with the amplitude? Thanks in advance!
BobTPH
Joined Jun 5, 2013
11,648
What is the supply voltage for the gates? A CMOS gate high output should be very near the supply rail.
Your voltage increase between 3 and 4 is not possible. It would indicate a current of 5mA from the input (!) of E to the output of B.
How are you measuring this? You need to use a scope.
Alec_t
Joined Sep 17, 2013
15,156
What does that wire exiting at top left connect to?
Is your 'scope probe AC-coupled or DC-coupled?
Are your measured voltages DC, AC peak-to-peak or AC rms?
Papabravo
Joined Feb 24, 2006
22,111
Measuring the amplitude of an AC signal of that frequency with a voltmeter is a profoundly misguided thing to do. You cannot possibly interpret the results in a meaningful way.
Sakux
Joined Mar 1, 2021
25
Thank you all for your responses. This line on the left leads to a pin of a micro to control the output. It puts the signal High impedance, 3.3 or 0. Of course I used an oscilloscope to measure this.It is in DC coupling. And the signal is measured using the amplitude quick measurement of the oscilloscope.
schmitt trigger
Joined Jul 12, 2010
2,229
You are loading the xtal circuit with your scope probe.
Some probes can place a 10 pF load, even on the 10X setting. Much worse at 1X.
At your crystal frequency, this means about 618 ohms load.
Even with a good probe, the load will be around 1500 ohm.
Sakux
Joined Mar 1, 2021
25
Yes, you are right. But how is this afecting with so much the amplitude of the signal in the different points? What I am missing?
Sakux
Joined Mar 1, 2021
25
Moreover I don´t really understand the second structure of the hex gate with this realimentation with the 47K.
Alec_t
Joined Sep 17, 2013
15,156
The 47k provides negative feedback to keep the DC operating point of the gate at about mid-rail voltage. The gate then acts as a more-or-less linear amplifier over a limited range.
35,180
What I see on pin-10 as an example, is a square-wave (digital) of about 3.3V amplitude.
I see overshoot and undershoot caused by the oscilloscope probe coupling.
74HCU04 is a digital gate. Don't expect to see a sine-wave signal.
Sakux
Joined Mar 1, 2021
25
So this gate is acting like something as an OA?
35,180
That's make sense, but how is this achieved the saturation of the original sine wave of the crystal?
The sine wave you see on pin-3 is the oscillation of the crystal.
Pin-3 input impedance is very high and does not load down the crystal oscillation.
