This is not good enough.This was the change I made, but LED remains off.
Code:void loop() { digitalWrite(LED, HIGH); delay(3000); digitalWrite(LED, LOW); }
You need to insert another delay instruction.
Okay, will do it tomorrow and get back.This is not good enough.
Well, I can't say about. Maybe the 10k baising resistor is pulling it low.If RESET is pulled low, the chip will do nothing, so that makes sense. But why is it low?
Just saying… without a second delay after writing the LOW to the LED, the effect will f this sketch to the human eye is as if the delay and the digital write of LOW never was there.This was the change I made, but LED remains off.
| Thread starter | Similar threads | Forum | Replies | Date |
Help to Soldering a tiny through-hole | PCB Layout , EDA & Simulations | 13 | |
Measuring tiny currents | Test & Measurement | 27 | |
Those tiny common 5V supplies... | General Electronics Chat | 16 | |
| R | VCO stuck with tiny range | Analog & Mixed-Signal Design | 14 | |
ATtiny85 upload on Sparkfun Tiny Programmer 11801 250502 | Microcontrollers | 2 |
