Asynchronous 4-Bit Counter
Bob_Yang
Joined Nov 17, 2019
Hi, I'm a beginner for the digital circuit. Recently I encounter a problem when trying to implement a 4-bit counter by using Quartus. Following are my diagram and simulation outcome, the problem is why the simulation is not correct? I hope someone can help me, thanks!
Diagram
Simulation
SteveSh
Joined Nov 5, 2019
109
Quartus is a FPGA design tool from Intel.
Try asserting (taking it low) the reset early in the simulation sequence. The problem may be that the simulator assumes the flip flops come up in an unknown state. Once they're in an unknown state, even though they may be toggling, the simulator doesn't know what their state is.
Bob_Yang
Joined Nov 17, 2019
Yes, you're right. I just figured out what the problem is according to my professor's advice. thanks, anyway.
Bob_Yang
Joined Nov 17, 2019
Hi, all, this problem is solved and I get the exact result I want now. thanks for your helpful advices.
So, I need to close this thread or mark it as solved?
Simulation
ci139
Joined Jul 11, 2016
2,023
besides the reset , another thing is which are the defaults and how the voltage and threshold levels are set for the gates . . .
ci139
Joined Jul 11, 2016
2,023
But glad found this site : learned ALOT from people here than that school : alot gained..Alot..wish can get degree from this site
You should study all things from all sources (directly) related to your (future) job ←
You can study everything else you're interested in but it's best to have a paper on ↑
