Astable 555 circuit with a period of up to 10mins
JulesP
Joined Dec 7, 2018
458
Hi there,
I would like some help designing a 555 timer astable circuit that has a flip time of up to 5 mins (Period 10mins) and a mark to space ratio of exactly 50%. I have built three versions based on circuits from contacts and websites and they all are not quite right when it comes to measuring the parameters.
I have shown the three I have used so far in the three attached graphics. No 1 I could not get to work at all, No 2 can give me a good 120s period but the two states were not of equal duration and out by about 7 secs over that time. No 3 similarly can give me the long periods but is again not equal.
The circuit is used to switch between two banks of batteries so that they have equal discharge and charging times. Is there another circuit variation that will provide a period of 120-600s and equal durations of high and low?
I appreciate any thoughts,
Jules
AlbertHall
Joined Jun 4, 2014
12,625
You are really pushing the envelope trying to get accurate long periods from a '555.
You don't say which flavour '555 you are using. You would stand a better chance with a CMOS version (LMC555, TS555...).
Schematic 3 is the way to go.
AlbertHall
Joined Jun 4, 2014
12,625
The SE555 is not CMOS. The CMOS types have lower leakage so you can use higher value resistors and lower value capacitors. Electrolytic capacitors are also leaky - you might consider using a tantalum for the timing capacitor for lower leakage.
JulesP
Joined Dec 7, 2018
458
Alec, I'm not familiar with that option. Does the 555 still use the same components for the period i.e in my case 1000uf and 100-200k? Or does the flip flop IC contain or use external components to determine the period and is just triggered by 555 pin 3? Would you be able to send a sketch circuit?
Jules
danadak
Joined Mar 10, 2018
4,057
This will do the job. Board costs $4. Only external component is a cap for
power supply pin and the pot to adjust freq out. Using another pin for a jump-
er could disable the pot for a fixed 600 sec.
Takes ~ 8 lines of code. 50% is exact, timing (period) is +/- 2%, but thats over a
T range of 40 °C to +105 °C .
http://www.cypress.com/documentation/development-kitsboards/psoc-4-cy8ckit-049-4xxx-prototyping-kits
Board shown below not actual size.
Same thing can be done with ATTINY85, 8 pin dip, programmed
in basic language. Did not look up timing accuracy.
Regards, Dana.
eetech00
Joined Jun 8, 2013
4,705
Hi
Use a CD4060B, its better suited for accurate long time periods and already has the internal digital components to provide an output at 50% duty cycle.
eT
JulesP
Joined Dec 7, 2018
458
I'm not clear which of the items shown on the 'TopDesign.cysch are on the purchasable board. Is the PWM and the ADC-SAR_Seq_1 on this board?
Is Clock_1 from the 555 setup to deliver 100Hz? And on the PWM what is 'tc' and where does the Reset come from? Which component is the CD4060?
Sorry but electronics is not my primary skill.
Jules
eetech00
Joined Jun 8, 2013
4,705
Jules
The CD4060B is counter that has a built in, adjustable oscillator, and multiple outputs.
Each output produces a time delay based on the oscillator frequency. The oscillator can be RC based, or for more accurate time, a crystal can be used.
eT
bertus
Joined Apr 5, 2008
22,921
I would agree with that.
The timing accuracy will depend on the quality of the capacitor.
When the capacitor is temperature dependend, the timing will change with the temperature.
Bertus
Alec_t
Joined Sep 17, 2013
15,117
Here you go. In view of the above comments the internal clock oscillator of the 4060 is not used here. Period timing accuracy is dependent on the 555 and C2. Mark/space ratio is set accurately by the binary counter IC. Note the timing cap no longer needs to be an electrolytic. You could make R1 a 500k pot if you want timing adjustment.
34,807
There is more than one way to skin this cat.
If you must use a 555-timer, use a CMOS version such as LMC555 or TLC555. Do not use an electrolytic capacitor which means your capacitance has to be less than 10μF. Use a multi-stage counter such as CD4020, CD4040 or CD4060. This will guarantee 50% duty cycle output.
You can also use the CD4060 directly with a simple RC oscillator and this should work well.
If you want very stable timing, use a quartz crystal to give you better than 10 ppm accuracy.
You can use a 32768Hz crystal on a CD4060 followed by a second multistage counter to give you long time periods.
If you are in microcontroller programming, the simplest single chip solution is to use a low power MCU with a 32768Hz crystal. Such a solution will run on a button battery for years. I have a blog to show you exactly how to do this using an MSP430 MCU.
