assembly code LED on
Joined Apr 26, 2018
how can i get led on using assembly code
in my class we only have learned about ld, out and heard that we can turn led using only ld out
there are 8 leds at board and i have to turn 4 leds on
ORG 0000H
LD A,00000001B
OUT (00000011B),A
DEC A
LD A,00000010B
END
this is what we have done in class and i still dont get what i have to do...
we use z80
ericgibbs
Joined Jan 29, 2010
21,551
hi 111,
Welcome to AAC.
Are the 4 LED's connected to 4 separate Z80 pins, via a current limiting resistor.??
Did you write that Code fragment.?
E
Joined Apr 26, 2018
all the LEDs are connected to different pins with resistor.
and that code is one of the code that professor explained us about turning light on
