Ok, when I saw metalized foil caps I was thinking of the plastic box style like the Wima FKP and FKS types.Yes, both ends connect to foil, but one end is connected to the "Outer Foil" which shields the inner foil from noise.
| M | Running LEDs with no resistors | General Electronics Chat | 24 | |
series resistors Vs. lowering the voltage | General Electronics Chat | 9 | |
| J | Theory Question About Pull Down Resistors | Microcontrollers | 12 | |
Resistors and Johnson noise | General Electronics Chat | 1 | |
| T | Can you amplify a signal with only resistors? | General Electronics Chat | 84 |
