Arduino with ps2 for 2-motor control
beatsal
Joined Jan 21, 2018
425
I am trying to program a UNO to control a robot to move forward and back using a ps2 with joystick. I want to control the speed by moving the js on x-axis and direction by moving js on y axis. The foll. code works but without js controls. Now want to include js controls. Any help appreciated.
C:
void setup() {
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
    //Setup Channel B
  pinMode(13, OUTPUT); //Initiates Motor Channel B pin
void loop(){
     //Motor A forward @ full speed
  digitalWrite(12, LOW);  //Establishes backward direction of Channel A
    analogWrite(3, 255);    //Spins the motor on Channel A at half speed
    //Motor B forward @ full speed
  digitalWrite(13, HIGH); //Establishes forward direction of Channel B
    analogWrite(11, 255);   //Spins the motor on Channel B at full speed
      delay(1000);}   >/
Moderatots note : please use code tags for pieces of code
KeithWalker
Joined Jul 10, 2017
3,627
Do you have a program on the PS2 that will output joystick X and Y positions?
How do you plan on communicating them between the PS2 and the UNO?
beatsal
Joined Jan 21, 2018
425
I have a program for that which includes LCD display and other stuff. I will be using only the joystick movements of this program i.e. x-axis and y-axis. This has to blend with the program I posted earlier.
#include <SoftwareSerial.h>
#include <Cytron_PS2Shield.h>
Cytron_PS2Shield ps2(2, 3);
#include <LiquidCrystal.h>
//LCD pin to Arduino
// tested on 26/6, only left motor runs continu
const int pin_RS = 8;
const int pin_EN = 9;
const int pin_d4 = 4;
const int pin_d5 = 5;
const int pin_d6 = 6;
const int pin_d7 = 7;
const int pin_BL = 10;
char line1[16];
char line2[16];
int x = 0;
int y = 0;
int dir = 1;
LiquidCrystal lcd( pin_RS, pin_EN, pin_d4, pin_d5, pin_d6, pin_d7);
void setup() {
// put your setup code here, to run once:
ps2.begin(9600);
Serial.begin(9600);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print(" ");
lcd.setCursor(0, 1);
lcd.print(" ");
void loop() {
x = ps2.readButton(PS2_JOYSTICK_LEFT_Y_AXIS) - 127;
if (x >= 0)
dir = -1;
else
dir = 1;
y = abs(x);
sprintf(line1, "%d ", x);
lcd.print(line1);
//Serial.println(line1);
Serial.println(y);
Serial.println(dir);
sprintf(line2, "%d" , y);
//lcd.print(line2);
Serial.println( ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS));
if ( ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS) < 120 ) {
Serial.println("LEFT");
if ( ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS) > 134 ) {
Serial.println("RIGHT");
if ( ps2.readButton(PS2_JOYSTICK_LEFT_Y_AXIS) < 120 ) {
Serial.println("forward");
if ( ps2.readButton(PS2_JOYSTICK_LEFT_Y_AXIS) > 134 ) {
Serial.println("reverse");
delay(1000);
beatsal
Joined Jan 21, 2018
425
I have tried to combine the above 2 programs and came up with this. Any comments appreciated - thanks.
/< #include <SoftwareSerial.h>
void loop(){
analogWrite(3, 255); //Spins the motor on Channel A at full speed
delay(1000);}
int x = 0;
int y = 0;
int dir = 1;
void setup() {
ps2.begin(9600);
Serial.begin(9600);
//Setup Channel A
//Setup Channel B
pinMode(13, OUTPUT); //Initiates Motor Channel B pin }
void loop() {
if (x >= 0)
dir = -1;
else
dir = 1;
y = abs(x);
Serial.println(y);
if ( ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS) < 120 ) {?????
if ( ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS) > 134 ) {?????
woozycactus
Joined Jan 4, 2021
113
C:
void setup() {
  //Setup Channel A
    //Setup Channel B
void loop(){
      delay(1000);}   >/
is this what your looking for?
int speedPin=5;
int dir1=4;
int dir2=3;
int mSpeed;
int jPin=A1;
int jVal;
void setup() {
pinMode(speedPin,OUTPUT);
pinMode(dir1,OUTPUT);
pinMode(dir2,OUTPUT);
pinMode(jPin,INPUT);
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
jVal=analogRead(jPin);
Serial.println(jVal);
if (jVal<512){
digitalWrite(dir1,LOW);
digitalWrite(dir2,HIGH);
mSpeed=-255./512.*jVal+255.;
analogWrite(speedPin,mSpeed);
if(jVal>=512){
digitalWrite(dir1,HIGH);
digitalWrite(dir2,LOW);
mSpeed=(255./512.)*jVal-255.;
beatsal
Joined Jan 21, 2018
425
int speedPin=5;
int dir1=4;
int dir2=3;
int mSpeed;
int jPin=A1;
int jVal;
void setup() {
Serial.begin(9600);
void loop() {
if (jVal<512){
if(jVal>=512){
Yes, thanks, just what I'm looking for. Will try it out if it works.
beatsal
Joined Jan 21, 2018
425
I tried it and it compiled and uploaded fine but when I tried to run the motors using the ps2 joystick, nothing happened. Not sure what the problem is.
beatsal
Joined Jan 21, 2018
425
I know this program below works directly (without ps2 or joystick) as it turns both motors. Pins 12, 13 establish the dir. and pins 3, 11 the speed {PWM). I use a motor shield as I drive 12 VDC motors.
/< pinMode(12, OUTPUT); //Initiates Motor Channel A pin
//Setup Channel B
void loop(){
delay(1000);} >/
KeithWalker
Joined Jul 10, 2017
3,627
Do it in small steps. First get the results from the PS2 to see what is happening. What is the communications link between the PS2 and the Arduino?
Make a simple program to run on the Arduino that will receive the joystick signals from the PS2 and display the values on the computer monitor. Once you have that working, it will be easy to combine with the motor program.
beatsal
Joined Jan 21, 2018
425
I am not able to write the js/ps2 position, it jumps all over the place. Trying to write the js current position to 2 output pins to control 2 motors vis a arduino motor shield.
C:
/> //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin dir
  pinMode(13, OUTPUT); //Initiates Motor Channel B pin dir
      //Setup Channel B
void loop(){
  //if ( ps2.readButton(PS2_JOYSTICK_LEFT_Y_AXIS)  < 200 ) {
    //digitalWrite(12, LOW);  //Establishes backward direction of Channel A
  //digitalWrite(13, HIGH);  //Establishes backward direction of Channel B
    Serial.println(ps2.readButton(PS2_JOYSTICK_LEFT_Y_AXIS));
   //Serial.println(x);
     if (x > 220)
    dir = 1;
    else
    dir = -1;
    //Serial.println(dir);
  analogWrite(3, x);    //Spins the motor on Channel A
      analogWrite(11, x);   //Spins the motor on Channel B
      delay(1000);
Moderators note : please use code tags for pieces of code.
KeithWalker
Joined Jul 10, 2017
3,627
Until you get steady readings from the PS2 there is no point in trying to use them to control the motors. What results are you getting, and once again, what is the communications link between the PS2 an Arduino? I can't help you if I don't know what is going on.
beatsal
Joined Jan 21, 2018
425
These are readings I get from serial monitor without changing js position. I would expect 128 steady as js is in center position.
224
254
128
240
beatsal
Joined Jan 21, 2018
425
In this program, if I add the 2 lines below, I get erratic readings. If I remove them readings are steady.
//analogWrite(3, y); //Spins the motor on Channel A
//analogWrite(11, y); //Spins the motor on Channel B
int x = 0;
int y = 0;
int dir = 1;
void setup() {
ps2.begin(9600);
Serial.begin(9600);
//pinMode(12, OUTPUT); //Initiates Motor Channel A pin
//Setup Channel B
//pinMode(13, OUTPUT); //Initiates Motor Channel B pin
//digitalWrite(13, HIGH); //Establishes forward direction of Channel B
//pinMode(3, OUTPUT);
//pinMode(11, OUTPUT);
void loop()
//Setup Channel B
y = ps2.readButton(PS2_JOYSTICK_LEFT_X_AXIS);
Serial.println(y);
delay(1000);
KeithWalker
Joined Jul 10, 2017
3,627
If I understand correctly, you are getting valid data from the joysticks on the PS2 as long as no motors are running.
What supply are you using to drive the motors? Is it the same supply that is connected to the Arduino?
I would suspect that the motors are causing intererence on the supply that is affecting the Arduino.
Can you give us a wiring diagram please so that we can see how it is connected.
beatsal
Joined Jan 21, 2018
425
Thanks for your help. The problem was with the SW interrupt which was set at ps2(2,3) but pin 3 was used for the motor. Changed to 8,9 and works OK. Still not clear about the SW interrupt. Now, will have to work on controlled steering. If you have any ideas, please help.
