Control 3 phase motor with Arduino
rups22
Joined Oct 26, 2022
16
Morning all
I am looking to automate control of a 3 phase motor (230v 3kW) using an Arduino.
I assume I'll need some sort of contactor which I could control through a relay board connected to the Arduino. I'm having trouble locating an exact product to purchase and am looking for recommendations or even just the correct search terms.
Thank you in advance
MaxHeadRoom
Joined Jul 18, 2013
30,884
Contactors usually have a HP rating on them, if you need reverse capability then you require the dual interlocked version.
You can also get them in various coil voltages for AC or DC .
The Group Schneider/Telemecanique line are nice and compact.
bidrohini
Joined Jul 29, 2022
190
Morning all
You can get some idea from this video:
rups22
Joined Oct 26, 2022
16
Correct, no speed control required, I only need on / off
Ideally something less costly than simply mounting a stepper motor on to the rotary isolator switch and mechanically actuating it
rups22
Joined Oct 26, 2022
16
MaxHeadRoom
Joined Jul 18, 2013
30,884
A motor CB is normally rated at 1.3x the motor rated load. your motor is only 2.6a.
That contactor uses a 230vac coil, how are you going to control that with Arduino?
rups22
Joined Oct 26, 2022
16
MaxHeadRoom
Joined Jul 18, 2013
30,884
Also with a motor controlled contactor, it is usually followed by O/L (over load) unit, in most cases they connect into the bottom terminals of the contactor.
Usually they posses N.O. & N.C contacts in order to drop the coil out on O/L and also the N.O. can be used to input the control to advise it that an overload has occurred.
