Applications for Android phones...
Externet
Joined Nov 29, 2005
2,678
Hello.
Tried to install a Wifi walkietalkie application on each of two smart phones with no service and cannot find the same exact one in the application store. Happened often when trying to install applications am used to on a new phone. Cannot find the same exact one developed by the same person, same version. What is going on ? There is dozens of applications with the same name created by different people and adding the name of the creator to the search does not work.
Is there a trick to locate the exact same for installing in more than one device? What am doing wrong ?
How can an application on one phone be copied to another phone ?
Alec_t
Joined Sep 17, 2013
15,158
Ask ChatGPT " under what circumstances are apps in google play-store removed? " and you get a lengthy list of reasons why apps get removed from Play-store.
Externet
Joined Nov 29, 2005
2,678
Misexpressed: . While installing application xyz on one phone, simultaneously trying to do the same xyz on another phone, the application is not found. :(:(:(
BobTPH
Joined Jun 5, 2013
11,661
Just a guess, but perhaps the app requires some minimum version of Android and the second phone had an older version, so it was not listed.
