Application software protection mechanism
electronicsLearner77
Joined May 26, 2012
127
I have a requirement where i have to implement end - to - end protection mechanisms, like checksums on application level to protect data from corruption during transmission. How do I need to do this? What are the common check sum mechanisms i can use?
xox
Joined Sep 8, 2017
936
Lot's of ways to go about that. CRC's are popular because of their speed and robustness. Wikipedia does a pretty good job of covering the basic approach here. In general though, any function which maps a large set of bits to a smaller set and exhibits fairly optimal collision-resistance and "avalanching" (small changes in the data leading to vastly different hash codes) could work.
Of course many protocols already have some sort of error-correction built in. Are you sure that you actually need it? How is the data being transferred?
Joined May 26, 2012
127
Thank you for the reply. I am communicating over CAN bus. So when i am sending data i want to use the checksum calculation and the receiving end can make sure that the data is correct.
xox
Joined Sep 8, 2017
936
See section 1.2.2 of this document:
Error Handling
CAN implements five levels of error detection. At the message level, it performs cyclic redundancy checks,
frame checks and acknowledgment checks. Bit level checks consist of monitoring and stuffing.
Cyclical redundancy errors are detected using a 15 bit CRC computed by the transmitter from the message
content. Each receiver accepting the message recalculates the CRC and compares it against the transmitted
value. A discrepancy between the two calculations causes an error flag to be set. Frame checks that will flag
an error are the detection by a receiver of an invalid bit in the CRC delimiter, ACK delimiter, EOF or 3-bit
interframe space. Finally, each receiving node writes a dominant bit into the ACK slot of the message frame
that is read by the transmitting node. If a message is not acknowledged (perhaps because the receiver has
failed), an ACK error is flagged.
Adding yet another level of error-detection doesn't make much sense.
xox
Joined Sep 8, 2017
936
It is the customer requirement and mainly safety related automotive application. So, I have to do it.
That's it, append checksum to data sent and then verify on the receiving end.
Joined May 26, 2012
127
I have this requirement, 4 bit counter used in checksum calculation. X=Y (modulo 16). I don't have further details on this. Anything i can make out of it or what should i do? Do i need to get further details from the customer?
xox
Joined Sep 8, 2017
936
Anything you can make out what? I don't understand your question.
Do keep in mind that a 4-bit CRC is only going to be barely sufficient for up to about 16 bits (2 bytes) of data. That's a best-case scenario, assuming you've selected the right generator (safest bet: go with a primitive polynomial). Anything above that length of input is basically going to render the CRC pointless...
EDIT: 16 bits, not bytes
Joined May 26, 2012
127
i did not say it is 4 bit CRC. In 8 bytes of CAN data 1 byte (4 bits) will be a kind of counter increments from 1 to 16. One more byte will be the actual checksum which is calculated from this counter.
xox
Joined Sep 8, 2017
936
Okay, so you're saying that you intend to apply an 8-bit CRC to 4 individual bits within a 64-bit stream of data. Correct?
Joined May 26, 2012
127
This is the conclusion i arrived at. I have a signal "S" (10 bit information) which i need to protect it. To protect it I need to use a 4 bit counter and calculate the 8 bit checksum. The way the 4 bit counter used as i mentioned earlier (4 bit counter used in checksum calculation. X=Y (modulo 16)). I am not sure if I still miss some information or it is enough to calculate the checksum.
xox
Joined Sep 8, 2017
936
I still don't get it. What's the point of the 4-bit counter?
Joined May 26, 2012
127
My guess is something like this
Tx Message1: Signal_Value1, 1, checksum1
Tx Message2: Signal_Value2,2, Checksum2
Tx Message16: Signal_Value16,16,Checksum16
Tx Message17: Signal_Value17,1,Checksum17
and so on..
xox
Joined Sep 8, 2017
936
and so on..
So something along the lines of a frame number. But do you mean to apply the CRC to the counter, the payload, or both?
Joined May 26, 2012
127
I have seen this line in the document. "4 bit counter used in checksum calculation". I don't think the document is mistake. In any case i will try to get some help from them.
