Anybody know the name / part number of this pcb power terminal?
tomipiriyev
Joined Jan 26, 2019
5
this picture is better to understand what this terminal is for
https://i.ibb.co/VLTG4f4/picc.png
Mods Note:
You used the wrong file type to uploaded the image file, please don't upload the color image file as .png and you should converts to the .jpg format, the .png file already converts to the .jpg from 940,554 Bytes to 89,649 Bytes, it is almost 11 times of the file size from png to .jpg.
tomipiriyev
Joined Jan 26, 2019
5
Power bug is not same. The terminal on picture, ring til goes inside terminal and screwed from top. On powrr bug ring tip assembles over terminal doesn go inside the terminal.
shortbus
Joined Sep 30, 2009
10,050
I have checked these, but i couldnt find excactly the same type. On the picture it is for ring tip wire and on pcb pide terminal ring goes inside terminal and locked by screw .
Or they are the same and the vendor just didn't take the time to cut off the ring terminal and strip the wire.
tomipiriyev
Joined Jan 26, 2019
5
they are not the same, if you look carefully, i think the one on the picture it has metal art inside the connector with thread, when you rotate the screw, push the plate upward and tightens the ring inside
