Any woodworkers here?
dl324
Joined Mar 30, 2015
18,490
I don’t, but I want one and I’ve spent quite a bit of time to measure and design one. Trouble is I can’t find the right thickness of stock and have no way to cut it if I did. I could use an old blade for the stock but again, I don’t have anything to cut it. I’ve used a water jet cutter to do similar things for me but it’s not cheap.
You could use a piece of wood or angle bracket attached so it lines up with the right side of the slot in the throat plate.
You can buy them too:
wayneh
Joined Sep 9, 2010
18,180
Finally, done with the stone and time for some actual woodwork. Here are my two inserts. They're made from Ipé wood, a very dense and hard wood that lasts forever without treatment. Cool stuff, and beautiful. I should have washed off the dust from sanding before taking these shots - those stripes you see will disappear when the dust is off.
The inserts are anchored with 1/4" x 20 stainless screws threaded into concrete anchors, which required 1" deep, 1/2" diameter holes. I used a masonry bit and a hammer saw.
SLK001
Joined Nov 29, 2011
1,549
Back to woodworking, here is a curb find that someone in my neighborhood was tossing out. The top is a little rusty, but it should clean up nicely. I plugged it in and it worked! The only part that seems to be missing is the work hold-down. I can make that with a piece of 5/32 piano wire. It was all inclusive - it even came with a stand.
wayneh
Joined Sep 9, 2010
18,180
You said you used concrete anchors, have you ever tried Tapcons? My son turned me on to them and haven't used an anchor since. and no hammer saw needed:) The hole is small enough that a standard carbide tip twist drill will work just fine even with a cordless drill.
https://www.tapcon.com/
Yes! I like them and in retrospect I’d probably try to use them for this project if I were to do it again. I wanted to use stainless screws and that led me to the anchors but I don’t really like them all that much.
jpanhalt
Joined Jan 18, 2008
11,087
I second Tapcons. It was a long time ago, maybe late 70's, we were modifying a commercial space. I saw Tapcons used to secure the baseplate for steel studs. Nothing is easier and more effective.
SLK001
Joined Nov 29, 2011
1,549
Being exposed to the elements, SS screws were probably the correct choice. Tapcons are alloy steel and are subject to rusting.
wayneh
Joined Sep 9, 2010
18,180
That's a great score. Was it on craigslist or just a drive-by?
shortbus
Joined Sep 30, 2009
10,049
Not much of a worry. I just replaced my mail box that was anchored to it's stone base after around 8 years of being exposed to the elements. While the head of the Tapcon had slight rusting, the threads in the concrete landscaping stones were just like new. And this is right at the edge of the road, where winter salted slush gets on it.
MaxHeadRoom
Joined Jul 18, 2013
30,869
Something I just thought of that some might find useful is something I found on ebay, 163455114120, they are bamboo knitting needles, they make very nice hardwood pins or dowels for many projects I have found.
They are just a couple of $$'s for 55 assorted sizes.
They do have a silicone coating that for some applications may be sanded off.
Also good for outside applications. very dense wood.
Max.
