Any VCO IC working in 20MHz - 40MHz range?
dumindu89
Joined Oct 28, 2010
113
I want a VCO which is working in 20MHz - 40 MHz range. If you know such IC in TTL family please let me know the IC number.
35,183
74LS124, 74LS324, 74LS624 - 74LS629
to 20MHz, maybe short of your range.
You could add a frequency doubler or phase-locked loop.
dumindu89
Joined Oct 28, 2010
113
That will be hard to find.
A 74hct4046 (a 4046 derivative) will come the most close:
http://search.digikey.com/us/en/products/CD74HCT4046AM/296-9275-5-ND/376938
It will go upto 38 Mhz.
It is a PLL with VCO. I want just a VCO. Thanks for your help.
Thanks. But I found a better one by dropping the L of "74LS124". :) It is SN74S124
Can anyone tell me a VCO IC that work in FM broadcasting band too? But is should has a DIP package with through hole mounting.
35,183
I had forgotten about the 74S124 which I have used in the past.
The specs give a max freq of 60MHz while the description says 85MHz which is just shy of the FM band.
Again, a frequency doubler or phase-looked loop should do the trick.
22,111
I kinda doubt that a mini-circuit is going to be like a TTL part. It is going to look more like an RF-module requiring careful layout and impedance matching.
I tried entering that number (POS-ED8475) on the mini-circuits website and it returned no results. Why are you wasting our time with a bogus link?
Take the JTOS-50 which operates from a Vcc of 12 volts, covers 25-47 MHz, has at tuning voltage from 1-15 volts, and puts out +8.5dBm
Question: What is the peak to peak output voltage at an RMS current of 12 mA? If you had to think about it too hard, this part is probably not for you.
Question: What is the output impedance of the "RF output" on pin-13?
BTW What is the application for the VCO?
22,111
The 74S124 dual TTL VCO I.C. is still around and can operate up to 60 Mhz. Check it out.
It is far from clear that a digital part will be suitable for the intended application. It has now been over a decade since the post before yours and since the TS was last seen.
