Small size, easy to build. 0-30v, 2-5A all OK. Thanks
L Thread Starter LAOADAM Joined Nov 21, 2018 879 May 4, 2019 #1 Small size, easy to build. 0-30v, 2-5A all OK. Thanks
djsfantasi Joined Apr 11, 2010 9,163 May 4, 2019 #2 First, you can vary V or A. Not both. So which do you want (I assume from your title, you want to vary voltage)? What type of resolution do you want? 2V? 0.18V?
L Thread Starter LAOADAM Joined Nov 21, 2018 879 May 4, 2019 #3 djsfantasi said: First, you can vary V or A. Not both. So which do you want (I assume from your title, you want to vary voltage)? What type of resolution do you want? 2V? 0.18V? Click to expand... Thank you, yes, vary voltage. can the resolution be ~ 0.5V?
danadak Joined Mar 10, 2018 4,057 May 4, 2019 #4 https://forum.arduino.cc/index.php?topic=66916.0 https://www.instructables.com/id/Arduino-Controlled-Power-Supply-Source/ https://bestengineeringprojects.com/arduino-controlled-variable-power-supply/ Some possibilities. Regards, Dana.
L Thread Starter LAOADAM Joined Nov 21, 2018 879 May 4, 2019 #5 danadak said: https://forum.arduino.cc/index.php?topic=66916.0 https://www.instructables.com/id/Arduino-Controlled-Power-Supply-Source/ https://bestengineeringprojects.com/arduino-controlled-variable-power-supply/ Some possibilities. Regards, Dana. Click to expand... Thank you Dana, I'll try something there.
