And in the quiescent state, they draw only a very small leakage current.Depending on speed CMOS can be very low power which is really mandatory in battery powered applications.
So aka clock speed = 0 Hz.And in the quiescent state, they draw only a very small leakage current.
All these circuits use transistors.I do like the fact that you can build most simple IC's with just transistors
I was just emphasizing the point that CMOS draws not just low power, but essentially no power when in the quiescent state or 0 Hz clock speed (if there is a clock).So aka clock speed = 0 Hz.
vis-a-vis MrAL: "Depending on clock speed".![]()
I like to point out deficiencies in designs i was at one time actually employed to do that so i have a lot of experience with engineers who get bugged because someone is telling them that they overlooked something, some of them take it as good advice and roll their sleeves up and dig deeper down into the theory behind it, while some take constructive criticism as a personal mockery. The ones that dig down into it get better, the others dont.I was just emphasizing the point that CMOS draws not just low power, but essentially no power when in the quiescent state or 0 Hz clock speed (if there is a clock).
Is there some particular reason that you seem to nit-pick my comments that are related to your posts?![]()
I don't see how that's a nit, but I guess my point is your nit.But hey, you nit picked first
I was taught to analyze the carp our of everything before it can be shipped. This makes you learn to catch things that can be overlooked. In control theory if the plane crashes you are going to feel very bad when you find out you did something wrong and didnt catch it before it became part of the product. Samsung recently had learned the hard way too when they had problems with one of their phone battery compartments. Lost a HUGE amount of money over something so simple..
I hope you two kiss and make up. Both of you have different opinions. Different experiences leading you to different conclusions.
Like two bakers arguing over who has the better loaf of bread. Both are good. Enjoy feasting on both loafs.
I guess my only point is that none of us are completely error free so it is good to get peer review. In fact, i think we should welcome it not try to fight it off. I appreciated it when someone checks out something i did especially if there was a mistake somewhere.I don't see how that's a nit, but I guess my point is your nit.![]()
No need to explain yourself to me mate. I think constructive criticism is a good thing. Maybe you and all the brain boxs on here can lay your opinion on my project https://forum.allaboutcircuits.com/...-solar-charge-controller.169230/#post-1506539I was taught to analyze the carp our of everything before it can be shipped. This makes you learn to catch things that can be overlooked. In control theory if the plane crashes you are going to feel very bad when you find out you did something wrong and didnt catch it before it became part of the product. Samsung recently had learned the hard way too when they had problems with one of their phone battery compartments. Lost a HUGE amount of money over something so simple.
If you look back in history you will find all kinds of errors like this where a simple analysis would have revealed the problem and it could have been corrected easily.
Hi,Most CD4xxx Cmos ICs are buffered, but with a 5V supply the output current with 0.4V of saturation voltage is only ONE mA. It can drive a current of 4mA into a dead short.
An old 74xx TTL with its 5V supply has an output low current with 0.4V of saturation voltage is much higher at 16mA.
74HCxxx is higher speed and higher output current Cmos.
Did they upgrade the entire line perhaps?Very few CD4xxxx ICs are not buffered. The CD4069 hex inverter is not buffered and has the same output current as a CD4xxxxB gate that is buffered.
Here are graphs from their datasheets. Look at the dismal output current when the supply is 5V, it is even less with a 3V supply.
