Any opinions or suggestions about this hybrid tube preamp ?
gaetan8888
Joined Nov 14, 2008
50
Hello
Here's the circuit with parts values.
Thank
Bye
Gaetan
38,481
My opinion is that a tube amp is an archaic amplifying device, and there is no good reason to use one (unless of course you have that magical "Golden Ear" that can hear the difference). :rolleyes:
danadak
Joined Mar 10, 2018
4,057
Looks OK. Biasing seems unusual, eg, static grid bias at ~ -18V.
Same for plate current, looks right on.
Regards, Dana.
gaetan8888
Joined Nov 14, 2008
50
Hello
I have done a Ltspice simulation using 12AU7 tube and with differents values for somes parts.
The thd spectrum look good.
Any thought or suggestions about it ?
Thank
Bye
BBee
Joined Dec 6, 2018
35
I am not sure about this one. I do quite a bit with tubes, and have made hybrid preamps, but my general approach has been to replace a fet front end with valve. Maybe a backward step, but it does work well and one big advantage is that front end overload damage is unlikely (I should say most of my work is with RF). I can see that the input circuitry is similar to tube circuitry. Putting aside the information given for the moment, I see one good reason for using fet input is lower noise. I suppose my thought would be to see the results compared with a purely tube design though, as I don't really see the point of sacrifice of (possible) advantages of tubes and placing one in a less advantageous position with attendant complexity.
Tracy
bertus
Joined Apr 5, 2008
22,917
I would have expected a capacitor between the pot and the gate resistor of jfet.
I think that without the capacitor the DC settings of the jfet will be influenced, depending on the pot setting.
Bertus
TANDBERGEREN
Joined Jan 20, 2014
90
Theese old people is more drawn to the fact that tubes are "warmer". (Yes, actual temperature, not the sound)
All to often they confuse the two terms.
Somebody bring them wood-amps?
Audioguru
Joined Dec 20, 2007
11,248
Even harmonics distortion produced by a vacuum tube are exactly octaves apart and do not sound awful, but should not be there. Odd harmonics distortion is not musical (sounds awful, something like a buzzer) and is usually caused by push pull tubes close to and beyond symmetrical clipping.
