Any affordable freq analyzers out there?
Wendy
Joined Mar 24, 2008
23,856
The advent of relatively inexpensive test equipment (spectrum analyzers are a case in point) got me wondering. Wen I was a tech for Collins Radio and later Alcatel, freq analyzer were common. The big uses were tuning filters. Is their any low cost units out there?
We used old stuff like this for basic transmitter spectrums.
Everything cheap today is SDR based.
Wendy
Joined Mar 24, 2008
23,856
Basically it on mt wish list. Think audio to start, then up to 10MHz, like I said tuning filters and whatnot. $500.00 or less. A freq analyzer sweeps through a range, which a spectrum analyses most definitely will not
Sure spectrum analyzers sweep through a range. A frequency analyzer is just the old and maybe original name for a spectrum analyzer. What you likely want is a spectrum analyzer with a tracking oscillator. The tracking oscillator matches the tuned frequency of the spectrum analyser frontend so you can plot the frequency response of something.
https://forum.allaboutcircuits.com/threads/type-of-electrical-circuit.178907/post-1628195
Normalized frequency response of a wire using the tracking oscillator.
A quick and dirty Interdigital Filter response plot using that normalized wire calibration.
SamR
Joined Mar 19, 2019
5,538
I can do that with my function generator in sweep mode up to its 30MHz limit and run it into my digital scope which will record and store the sweep. Then I can pull it apart to my heart's content. I can even run a Bode plot on it!
Wendy
Joined Mar 24, 2008
23,856
What is your function generator?I priced the Rigol DSA 815. For me it is just on the edge of affordability. Every month I save $50 for things like test equipment.
Just for the halibut I am going to set $500 as the Max I am willing to spend thank you for all your responses truth is I have no use for it at the moment but I will.
SamR
Joined Mar 19, 2019
5,538
Here is the cheap one I have on the bench. Comes under many brand labels. Mine is a Kuman although I've upgraded a couple of times and now mainly using a Siglent SDG1032X which has a few more bells and whistles. But these do sweep @ up to 24MHz and are also a frequency counter as well. The actual works inside could fit in a cigarette pack, the box is for show and uses a wall wart for a power supply. No shielding or grounding but does work well and pretty much on spec. I just grabbed the first one I came to on Alix and you can do better on price with shopping around. Also depends on what max Freq you want. Higher Freq+Quality = Higer $.
If you buy one be sure it's the Rigol DSA815-TG with the tracking generator. It's a very good deal as an old R&S is a lot more.
I also have a old Chinese AT5010 (with no tracking generator). Useful for general RFI/EMI sniffing but that's about it.
https://www.manualslib.com/manual/1250649/Atten-At5010.html?page=9#manual
Wendy
Joined Mar 24, 2008
23,856
This thread has taught me a lot, thank you. Right now I am not sure what the heck I want. But I now have a lot to think about. I am rarely in the RF business nowadays. Audio is probably going to be more my speed.
SamR
Joined Mar 19, 2019
5,538
Most of the Audio ones I've seen listed were for setting up rooms for audio and recording sessions. I.E. Concert halls and such.
If you want simply audio then a PC based version might work.
For example:
I've used early versions of this software.
https://www.roomeqwizard.com/
https://forum.allaboutcircuits.com/...st-dedicated-home-theater.160250/post-1398002
Audio response from inside my car using very old ETF software.
tautech
Joined Oct 8, 2019
507
Few if any of the modern analyzers go below 9 kHz.
TG performance doesn't go that low either.
A modern DSO with good FFT and Bode Plot capability in conjunction with a AWG may be better suited to your needs.
