Antenna Gain
Papabravo
Joined Feb 24, 2006
22,111
What is the difference between -ve and +ve Gain of antenna. And which is better.
You may have conflated two different things. Gain of an antenna is measured in dB with respect to a reference such as an isotropic radiator or a dipole.
-ve and +ve refer to the negative and positive supply voltages in a power supply which might be used in an amplifier circuit.
sgr
Joined Jun 27, 2017
34
Hi Papabravo
your 1st statement is correct but 2nd statement is wrong. antenna is there with both +ve and -ve gain.please study the below antenna having Part No. HA.21.A and FR05-S1-R-0-105.
but i am unable to understand about these two gains
LesJones
Joined Jan 8, 2017
4,538
Negative gain is the same as a loss. So if your test antenna had a +3db gain with respect to an isotropic antenna then you could say that the isotropic antenna had a -3db gain with respect to the test antenna. NOTE an isotropic antenna is not a physical antenna. It is a concept antenna where the power is evenly distributed over the surface of a sphere.
Les.
Papabravo
Joined Feb 24, 2006
22,111
Hi Papabravo
There is no antenna below. Did you meant to include a link? The part number is great, but it is of little help without a manufacturer.
The second statement is also correct , regardless of whether it is used in your context which you did not explain or provide a link to.
