Another Reverse Polarity Protection Thread - NMOS
AF_Maxwell
Joined Dec 12, 2018
36
I want to implement the following scheme but charge pumps with a 40V output are too expensive for my needs.
Fig 3.
https://www.infineon.com/dgdl/Rever...2.pdf?fileId=db3a304412b407950112b41887722615
The only affordable component is DGD2101M but it uses some kind of bootstrap topology and I can't tell if it's analogous.
https://www.diodes.com/assets/Datasheets/DGD2101M.pdf
What's likely to result if I put a diode between COM and ground to protect DGD2101M from reverse polarity like this? There's no way to simulate it and I'm not familiar with the internal structure of the chip so should I expect it to work, has anyone done something similar before?
