another op-amp transfer function
WBahn
Joined Mar 31, 2012
33,122
I make the transfer function as ...
\(H(s)=\frac{s(s+9000)}{(s+2000)(s+4000)}\)
Correct (except for the units).
\(H(s)=\frac{s(s+9000sec^{-1})}{(s+2000sec^{-1})(s+4000sec^{-1})}\)
I absolutely HATE the fact that the accepted variable for the Laplace transform is 's' since this collides with the symbol for seconds and since the units associated with the variable s are inverse seconds.
As a personal shorthand (and which I usually don't even mention to other people or my students) I use the following definition:
1\$ = \frac{1}{1s}
Where, here, 's' is the symbol for seconds.
My choice of the dollar sign is not arbitrary, though it has nothing to do with the notion that time is money. Consider the quantity of a changing current, namely amps per second. The units would commonly be written as "A/s", which is the same as multiplying amperes by inverse seconds. Now, consider the similarity between "/s" and "$", namely a line and an 's' combined. So "A/s" is the same as "A$"
So I would tend to write the answer as:
\(H(s)=\frac{s(s+9k\$)}{(s+2k\$)(s+4k\$)}\)
Notice that checking for units consistency is easy since 's' and '$' look very similar and have the same units. It takes a while to get used to it and I freely admit that I think of 's' as having units of 'dollars' mentally and remind myself that a 'dollar' is an inverse-second when I need to.
panic mode
Joined Oct 10, 2011
5,202
WBahn is right, i did use 25k for R2. using 20k makes it 9000 and exactly as what t_n_k calculated. derill, ball is in your court... (have to wake up in 2h, zzzzzz)
derill03420
Joined Oct 15, 2011
26
Thank you guys for helping, and again I say I agree with tracking units I realized that fact in physics as tracking units was only way to tell 100% that my answer was correct and most students who failed didn't track and cancel units! Just not used to doing in circuits but I will change my ways in circuits.
I got 2 more practice problems to do which I will be posting after work about state variables which prof spent very little time on and honestly I need help
