aneng q1 multimeter cant read the DC voltage correctly
Thilanka Kodikara
Joined Sep 30, 2017
10
Hi
i have bought a aneng q1 multimeter before 6 month back but now i got a issue when im measuring the DC voltage , it shows the value but it shows the value bellow the correct one, then it is gradually comes to the correct voltage after few minutes, also if i change the polarity multimeter shows diffrent DC voltage , so how to solve this issue , please hep me.
Ian0
Joined Aug 7, 2020
13,271
How do you know it doesn't work? What are you comparing it to?
Does everything else work?
Does the DC voltage range use the same sockets for the probes as the ranges that work?
WBahn
Joined Mar 31, 2012
33,177
Hi
What is it that you are measuring the voltage of? Meters always interact with the circuits they are measuring, and sometimes that effect is quite noticeable.
dl324
Joined Mar 30, 2015
18,462
Have you checked the battery?
