android box antenna help
Mike Boudreau
Joined May 20, 2018
12
hi friends
I'm trying to put an external antenna on my android box usIng sma connector and thread on antenna whip .
On the pc board there are tx rx and ground terminals .
Now on the sma connector there is centre core wire and outer edge .This is a thread on through hole type connector.
Can anyone help with what terminal goes where?
thanks
Mike Boudreau
Joined May 20, 2018
12
SORRY Dodgydave
Please read the question.
WIFI antenna!WIFI is send and receive signals.The antenna whip has a small coaxial cable with centre wire. and outer braided sheath just like cable tv, cable has. The antenna has a sma connector.the original question reads.I'm trying to put an external antenna on my android box usIng sma connector and thread on the antenna whip .
