And the robbery keeps rising...
Externet
Joined Nov 29, 2005
2,676
Soldering iron tips. :mad:
As soon as the chinese find out; they will tenfold their prices too... just imagine if the demand of these was higher as in the eighties. Then they would ask $100 each.
schmitt trigger
Joined Jul 12, 2010
2,240
Speaking of cleaning… how do you prefer to clean the tip, with a wet sponge or with a brass braid?
Me? I prefer the wet sponge. The braid I only use if the tip has a cooked flux buildup.
I ignore whether this is optimal or not.
atferrari
Joined Jan 6, 2004
5,029
I use thick high quality paper napkins used in the bar of waves-piercing ferries built in Tasmania still crossing from Bs .As - Montevideo. Current bunch expected to last a long time.
Ya’akov
Joined Jan 27, 2019
10,305
The Hakko 599B Tip Cleaner is the ideal cleaning alternative to the traditional wet sponge. The non-abrasive brass shavings is tough enough to scrub residual solder from your soldering tools without your soldering iron becoming cool.
https://hakkousa.com/catalog/product/view/id/5960/s/599b-tip-cleaner/category/2/
MSDS: https://hakkousa.com/amfile/file/download/file/908/product/5960/
I… sit... corrected. The alloy of brass being used seems a lot harder than other brass I encounter. I still reserve “wool” as the corrected nomenclature, so “brass wool” it is.
They call it “shavings” which I suppose it is, but it is made into metallic wool and it is certainly not “braid” in any case.
Thanks for point that out.
cmartinez
Joined Jan 17, 2007
8,862
I used to clean my iron's tips using a wet sponge. But then I discovered that I could clean it much more efficiently (and effectively) by simply grabbing a thick, dry napkin and squeezing and wiping the iron's tip with my hand. It's a quick operation, so the napkin never burns and barely browns on its surface ... It's good that I don't have a safety inspector looking over my shoulder when I'm working on one of my circuits ... :D
They likely buy (or once did) the shavings in bulk as waste from some type of brass machining process.
The only why I would know such details is that the work safety dept. requested MSDS data and heavy metal sampling for the repair and rework stations. They wanted to make us use lead-free solder for repairs but the EE dept. said, hell no, we have internal use and high reliability exceptions from RoHS (Restriction of Use of Hazardous Substances) regulations.
