joeyd999
Joined Jun 6, 2011
6,443
o_O ... to annoy your neighbors? ... :D
No, I actually wanted the road to play the William Tell Overture. I thought it'd be cool on an open road...but I was worried about the frequency response of the road/car.
Edit: I even envisioned a machine that would lay the bumps or cut grooves based on a computer file.
It's all about money.
http://www.chicagotribune.com/news/...et-red-light-camera-tickets-120617-story.html
https://arstechnica.com/tech-policy...ion-bogus-traffic-tickets-from-speed-cameras/
http://www.chicagotribune.com/news/...red-light-cameras-suburbs-20180105-story.html
A decade later, we haven’t seen any epic change in driving behavior. And if you still think the main objective was safety rather than revenue, we have some suburban bridges to sell you.
What’s become clear is that many local officials have little interest in the safety results — but they do care about the revenue. Even worse, when there is a clear conflict between preventing accidents and raising money, money gets priority.
That’s the only inference to be drawn from an investigation by Tribune reporters Joe Mahr and Matthew Walberg. “After cameras were installed, the crash rate rose at one-fourth of the places that could be studied,” they found. But the Illinois Department of Transportation has failed to revoke the permits it provides for these cameras.
cmartinez
Joined Jan 17, 2007
8,842
I can live with Rossini's masterpiece... but imagine if that infernal device were programmed with the tune of an excruciatingly annoying commercial jingle ... something like: "brush your breath, brush your breath, brush your breath with dentyne!" :eek::mad:
Say this five times. Mystery monkey mummy
https://www.mprnews.org/story/2018/04/10/mystery-monkey-skeleton-dayton-demolition-minneapolis
Interestingly, Robbinsdale Mayor Regan Murphy says he may know the riddle of the monkey.
"My dad once stole a monkey from a Dayton's display back in the 60s," Murphy wrote on Twitter. "They decided to bring it back after it shat all over my Dad's friends bedroom while they were at school. They returned it by letting it loose in the store.
"This is probably that monkey."
WBahn
Joined Mar 31, 2012
33,080
Years and years ago there was a fad in which greeting cards came with a plastic strip that looked like a zip tie, but if you pulled it through your thumb and forefinger with your thumbnail on the ridges it would say, "Happy Birthday," or whatever. The first time I say that I thought it would be a cool thing to make the rumble strips speak to you as if from God.
I wonder if I could have patented the idea. Oh well.
cmartinez
Joined Jan 17, 2007
8,842
https://www.independent.co.uk/news/...borg-collapse-wrong-way-library-a8295651.html
You can see the 'hinge' failure better on this shot. The entire cut section of the Silo drops in a slide (shear) to the solid base causing the 'hinge' to be on the opposite detonated side.
I'm wondering what caused it to hinge in the opposite direction ... possibly some resonance in the structure when it first hit the ground vertically (likely)? An unbalance in its vertical symmetry axis (doubtful)?
The downward momentum of the building falling from the top was converted to angular momentum in the wrong direction when the cylinder bottom slid off the Silo base in the back after the explosion in the front created a large gap for a dead drop of the front. This caused a rotation in the entire structure. Once the 'new' bottom of the Silo was resting on the base the top just continued this rotation toward the building.
