I just wanted to see if the chip works, so I made the circuit above. I just connected the chip to the 5VDC supply and took the first output and connected it to a led through a 100Ω resistor. The cathode of the led goes to the ground. I believe the led should not light up.
The resistor and the ground of the chip don't touch each other,
