Hello there,
I buit this simple AND gate :
but unfortunately it doesn't perform as I expected.
First, I was always told to never connect the load to the NPN emitter pin. Does anyone know why it's the case in this schematics?
Second, whenever the B port is high, the OUT port is high too.
My setup is the following: VCC is 5V, A and B are driven by PIR detectors that output 3.3V. R is 4.7K and the NPN transistors are 2N2222.
Now, when only A is high, OUT is down.
when A and B are high, OUT is high (2.8V)
when B is high and A is down, OUT is high (2.2V)
Does anyone know what is wrong with this gate?
Thank you.
Thank you.
