Normally not a factor with a CMOS circuit, since it consumes only a very small leakage current when static.He might be concerned with the current consumption, which will be inherently higher if the IC has more circuits to bias.
Long form answer for the TS . . .Is it not the output impedance load that you want to be >20kΩ?
I know, but I assume that even in CMOS there are biasing circuits that consume more for more channels.Normally not a factor with a CMOS circuit, since it consumes only a very small leakage current when static.
If I recall correctly, as long as the unused input pins are tied to a solid one or zero level, and the outputs unconnected, those unused gates would only consume leakage current in the nanoamp range.I know, but I assume that even in CMOS there are biasing circuits that consume more for more channels.
Good to know. I was assuming the worst case scenario.If I recall correctly, as long as the unused input pins are tied to a solid one or zero level, and the outputs unconnected, those unused gates would only consume leakage current in the nanoamp range.
Yes, but then the output impedance needs to be very high to not attenuate the signal.One way to reduce this is to choose a switch such that its series resistance is a very small percentage of the downstream input impedances. I chose a target threshold of 1%, and the 4066 meets this if the analogue input impedances are greater than 20K ohms.
Use the correct relay for the application if you chose to use a relay.Relays for low current applications are not recommended, unless it's a solid-state relay. The contacts oxidize and start to not conduct with time.
Good to know there's these types of relays. A professor of mine once said what I said above, but didn't mention relays with gold contacts. Seems obvious now, but I didn't know it was a thing being sold.Use the correct relay for the application if you chose to use a relay.
I use low-signal rated relays with gold contacts for line level signals. They been reliable for decades in gear running 24/7.
https://www.mouser.com/catalog/specsheets/Pansonic_12-15-2025_TQ_Relays.pdf
| Thread starter | Similar threads | Forum | Replies | Date |
Noise on analogue audio line from proximity 12 VDC light circuits | General Electronics Chat | 3 |
